9 years agoI have some error to use OpenCL.. please help me.
Hellow guys, I have some problem to use opencl. I am using AOCL and quartus 13.1 version. My probelm is when i command " aocl diagnostic" the error are occcur. the message is belowe that. aocl ...
9 years agoMnay Thanks. Well.. I will try one more time and than if I fail, I give up. I want to check the process.
1, The FPGA connect PCI-E in Host PC then turn on. 2, Set the path for OpenCL 3, install the FPGA driver 4, command diagnostic -> failed This is my process. Is it standard procedure? Arranging my procedure, I have a one more question. If I command "aoc --list-board", two board are listed, xpressgx5lp_a4 and xpressgx5lp_a7. Does host CPU select the board automatically or select the board manually?
