9 years agoI have some error to use OpenCL.. please help me.
Hellow guys, I have some problem to use opencl. I am using AOCL and quartus 13.1 version. My probelm is when i command " aocl diagnostic" the error are occcur. the message is belowe that. aocl ...
9 years agoMany Thanks. Below is the script when i command "lspci -v". I don't see the Kernel driver and Kernel module you mention.
01:00.0 Unssigned class [ff00]: PLDA PCI Express Core Reference Design (rev 01) Subsystem: PLDA PCI Express Core Reference Design Flags: bus master, fast devesel, latency 0, IRQ 16 Memory at f0100000 (64-bit, prefetchable) Memory at f0104000 (64-bit, prefetchable) Capabilities: [50] MSI: Enable - Count=1/16 Maskable- 64bit+ Capabilities: [78] Power Management version 3 Capabilities: [80] Express Endpoint, MSI 00 Capabilities: [100] Virtual Channel Capabilities: [200] Vendor Specific Information:ID=a000 Rev=0 Len=044 <?> Capabilities: [300]# 19 Kernel driver in use: plda I am confused about opencl. What is diagnose? I think it is just test progrem about OpenCL maked by vecdor. So It doesn't need to compile the kernel. I think, just test FPGA board using the flash memory data not using kernel. But you mention kernel is precompiled. what is mean? If it need to precompile, what is precompile source? I mean that if compile command is "aoc --board <board name> source.cl, what is source.cl?
