9 years agoI have some error to use OpenCL.. please help me.
Hellow guys, I have some problem to use opencl. I am using AOCL and quartus 13.1 version. My probelm is when i command " aocl diagnostic" the error are occcur. the message is belowe that. aocl ...
9 years agoMy board is xpressgx5lp of PLDA. They are old board, right. Sadly, I don't have starting guide. I did it alone. Because the PLDA now change direction of their buisiness. So I am not supported by the board vendor.. But I have board BSP package. And README FILE in BSP specify the fact that this board are working with AOCL and Quatus 13.1. Do you recommad using the newest vesion of aocl and quartus?
many thanks. --- Quote Start --- What is your board? Every board has a starting guide that details how you should set up the board for first usage. Apart from that, the version of Quartus/AOC you are using is ancient; at this point in time, depending on the BSP available to you by the board manufacturer, you should be either using 16.1.2 or 17.0. --- Quote End ---
