9 years agoI have some error to use OpenCL.. please help me.
Hellow guys, I have some problem to use opencl. I am using AOCL and quartus 13.1 version. My probelm is when i command " aocl diagnostic" the error are occcur. the message is belowe that. aocl ...
9 years agoWhat is your board? Every board has a starting guide that details how you should set up the board for first usage.
Apart from that, the version of Quartus/AOC you are using is ancient; at this point in time, depending on the BSP available to you by the board manufacturer, you should be either using 16.1.2 or 17.0.
