mark_lee
5 years agoI download an example for the cyclone , when i use then example on the A10 .
I download an example for the cyclone , when i use then example on the A10 .get error like this :
Error (14566): The Fitter cannot place 6 periphery component(s) due to conflicts with existing cons...
EngWei_O_Intel
5 years agoHi Mark
It is not recommended and not a common practice to directly port a design from Cyclone V to Arria 10. You might hit into IP incompatible, pin assignment, and configuration issues. I would suggest you to look for Arria 10 sample design or create your own design by referring to your Cyclone V sample design.
Sample design for Arria 10 (NIOS related):
https://fpgacloud.intel.com/devstore/platform/?search=NIOS&acds_version=any&family=arria-10
Eng Wei
- mark_lee5 years ago
The problem is solved ,thanks
