I can't synthesis my module on Quartus 19.2
I'm using PAC with arria 10 gx board now.
After installing IAS 1.2.1(intel accelerator stack), Quartus 19.2 was automatically installed.
When did i synthesize small module such like AND GATE for test.
"The quartus Prime software quit unexpectedly" occurs
The preview report is below
Problem Details
Error:
Internal Error: Sub-system: SUTIL, File: /quartus/synth/sutil/sutil_device.cpp, Line: 1072
is_legal_device()
Stack Trace:
0xc4b88: SUTIL_DEVICE_IMPL::initialize_full_info() [clone .cold.57] (synth_sutil)
0x4bba70: new_verific::vrfx2_set_verilog_elab_flags(BASEX_ELABORATE_INFO*) + 0x301 (synth_vrfx2)
0x4bd78f: new_verific::VRFX2_EXTRACTOR::extract_hierarchy(char const*, BASEX_ELABORATE_INFO*, bool, bool, bool) + 0x3f5 (synth_vrfx2)
0x84b4c: QIS_RTL_STAGE::IMPL::elaborate_verific(QHD_PARTITION&, HDB_ENTITY*, BASEX_ELAB_INFO_CORE&) + 0x134 (synth_qis)
0x8d03f: QIS_RTL_STAGE::IMPL::elaborate(QHD_PARTITION&) + 0x11e1 (synth_qis)
0x8e6e6: QIS_RTL_STAGE::elaborate(QHD_PARTITION&) + 0xc (synth_qis)
0x5d16a: qis_elaborate + 0x205 (synth_qis)
0x4c942: TclNRRunCallbacks + 0x42 (tcl8.6)
0x4de7b: TclEvalEx + 0x68b (tcl8.6)
0xf3f0e: Tcl_FSEvalFileEx + 0x25e (tcl8.6)
0xf3ffe: Tcl_EvalFile + 0x2e (tcl8.6)
0x14167: qexe_evaluate_tcl_script(std::string const&) + 0x36c (comp_qexe)
0x1928c: qexe_do_tcl(QEXE_FRAMEWORK*, std::string const&, std::string const&, std::list<std::string, std::allocator<std::string> > const&, bool, bool) + 0x417 (comp_qexe)
0x1a213: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x558 (comp_qexe)
0x395e7: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::string const&, std::string const&, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0xe1 (comp_qcu)
0x41eea: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::list<std::string, std::allocator<std::string> >*, bool) + 0x259 (comp_qcu)
0x405c27: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x9d (quartus_syn)
0x1cdfd: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x5c5 (comp_qexe)
0x40578b: qsyn2_main(int, char const**) + 0x14b (quartus_syn)
0x3ebd0: msg_main_thread(void*) + 0x10 (ccl_msg)
0x40de4: msg_thread_wrapper(void* (*)(void*), void*) + 0x6e (ccl_msg)
0x11bec: mem_thread_wrapper(void* (*)(void*), void*) + 0x5c (ccl_mem)
0xc2ee: err_thread_wrapper(void* (*)(void*), void*) + 0x27 (ccl_err)
0x6c25: thr_thread_wrapper + 0x15 (ccl_thr)
0x41930: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x148 (ccl_msg)
0x405e10: main + 0x26 (quartus_syn)
0x21b97: __libc_start_main + 0xe7 (c)
End-trace
Executable: quartus
Comment:
None
System Information
Platform: linux64
OS name: Ubuntu 18.04.4
OS version: 18
Quartus Prime Information
Address bits: 64
Version: 19.2.0
Build: 57
Edition: Pro Edition
- EricMunYew_C_Intel
Hi, Cho
Are you using Intel DevCloud ?
May I know how did you run compilation ?
Hi, Cho
May I know which FPGA device you are targeting? did you install the device family?
Hi, Cho
Can you try to upgrading from 1.2 to 1.2.1 (according to page 39), and follow page 40 for upgrading the FIM and BMC. And you can follow page 46 to change the permission permanently.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qs-ias-v1-2-1.pdf
