BRRRRT
5 years agoI can't Install USB blaster.
I install Quartus Prime Lite 20.1.1. it successfully installed but usb blaster driver isn't.
I try to install manually but I failed every time. I try to find new driver, but it seems all driver dow...
- 5 years ago
That might be due to issue with USB Blaster. Kindly follow the workaround in KDB below (it is also applicable for USB Blaster):
Aiman
vg2
5 years agoHello,
Can you provide a similar link for USB-Blaster? It has the same expiration issue.
Thank you,
VG2
