12 years agoI declared the variables after "process" and now another error appears, involving the division operator. My new code is:
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_signed.all;
use ieee.std_logic_unsigned.all;
entity pwm_generator is
port( a, b: in bit_vector (31 downto 0);
c: out bit);
end pwm_generator;
--The input 'a' means the frequency, of signal pwm, in binary. For example 1234Hz is 00000000000000000000010011010010Hz
--The input 'b' means the duty cicle in binary. For example 27% is 00000000000000000000000000011011%
--The output 'c' means the output of pwm signal.
architecture logical of pwm_generator is
begin
process
variable a1, b1: integer;
variable t, e, f, b2: real;
--The variable 't' means the period (in seconds) of pwm signal.
--The variable 'e' means the time (in seconds) of the high level ('1') of the pwm signal.
--The variable 'a1' means the decimal representation of the input 'a'.
--The variable 'b1' means the decimal representation of the input 'b'.
--The variable 'f' means the time (in seconds) of the low level ('0') of the pwm signal.
--The variable 'b2' means the percentage in decimal of 'b1'.
begin
a1 := to_integer(unsigned(to_stdlogicvector(a)));
b1 := to_integer(unsigned(to_stdlogicvector(b)));
b2 := b1/100;
t := 1/a1;
e := t*b2;
f := t-e;
L1: loop
c <= '1';
wait for e;
c <= '0';
wait for f;
end loop;
end process;
end logical;
The error is: { Error (10327): VHDL error at teste_linguagem_vhdl.vhd(33): can't determine definition of operator ""/"" -- found 0 possible definitions }. About the "wait for" if don't work I'll change my idea.
