12 years ago --- Quote Start --- Hi everyone When I compile my code a problem with the syntax appears and I can't find the problem. The objective of my code is generate a PWM signal:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.numeric_std.all;
use IEEE.std_logic_signed.all;
use IEEE.std_logic_unsigned.all;
entity pwm_generator is
port( a, b: in bit_vector (31 downto 0);
c: out bit);
end pwm_generator;
--The input 'a' means the frequency, of signal pwm, in binary. For example 1234Hz is 00000000000000000000010011010010Hz
--The input 'b' means the duty cicle in binary. For example 27% is 00000000000000000000000000011011%
--The output 'c' means the output of pwm signal.
architecture logical of pwm_generator is
variable t, e, a1, b1, f: integer;
--The variable 't' means the period (in seconds) of pwm signal.
--The variable 'e' means the time (in seconds) of the high level ('1') of the pwm signal.
--The variable 'a1' means the decimal representation of the input 'a'.
--The variable 'b1' means the decimal representation of the input 'b'.
--The variable 'f' means the time (in seconds) of the low level ('0') of the pwm signal.
begin
a1 := to_integer(unsigned(to_stdlogicvector(a)));
b1 := to_integer(unsigned(to_stdlogicvector(b)));
t := 1/a1;
e := t*b1;
f := t-e;
process
begin
L1: loop
c <= '1';
wait for e;
c <= '0';
wait for f;
end loop;
end process;
end logical;
The error is { Error (10500): VHDL syntax error at test_language_vhdl.vhd(27) near text ":="; expecting "(", or "'", or "." } Thanks in advance. --- Quote End --- declare your variables after process. I am not sure if your code is synthesisable due to wait for.
