I am using quartus pro 18.1 I get a error unconstrained ports can only be associated in whole if I cast a unconstrained std_logic_vector to an unsigned for my generic memory
Try to build similar coding and able to compile successfully in Pro 18.1. Did not have the error message.
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
entity cast_test is
port
clk,wren : in std_logic;
address : in std_logic_vector (7 downto 0);
input : in unsigned(7 downto 0);
output,q_out : out unsigned(7 downto 0)
end entity cast_test;
architecture rtl of cast_test is
component RAM1P_w8
port (
data : in std_logic_vector(7 downto 0) := (others => '0'); -- ram_input.datain
address : in std_logic_vector(7 downto 0) := (others => '0'); -- .address
wren : in std_logic := '0'; -- .wren
clock : in std_logic := '0'; -- .clk
q : out std_logic_vector(7 downto 0) -- ram_output.dataout
end component;
component test
port
input : in std_logic_vector(7 downto 0);
output : out std_logic_vector(7 downto 0)
end component;
signal w_input : unsigned (7 downto 0);
begin
w_input <= input;
test_inst : test
port map (
input => std_logic_vector(w_input),
unsigned(output) => output
RAM1P_w8_inst : RAM1P_w8
port map(
data => std_logic_vector(w_input),
address => address,
wren => wren,
clock => clk,
unsigned(q) => q_out
end architecture rtl;
********************* Sub module ***************************
library ieee;
entity test is
port
end entity test;
architecture rtl of test is
begin
output <= not input;
- bswag7 years ago
Not quite similar my memory is unconstrained yours is constrained to length 8.
