AC1
8 years agoi am getting error as fitter cannot place one io_pll, cannot find a location with io_tile_lock_id of 77. this error i am getting in quartus prime 18.0. can any one help how to solve this problem
- AnandRaj_S_Intel
Can you elaborate on the steps.
- Which edition have you used?
- Can you share your design?
Anand Raj Shankar
- AC1
i am using quartus 18.0.
i am using jesd, pcie,ddr, nand and ethernet in my interface
- AnandRaj_S_Intel
I have tried to recreate the issue but not succeeded.
- I know you are using 18.0, I have asked you about the edition(Pro or Std)?
- You can share the design if possible.
Or to Debug the design
- Can you remove the IO PLL from design and compile design and check.
- Recheck the IP interface/ connections.
Anand Raj Shankar
