10 years agoHysteresis for temperature measurement
Hello all, I am using MAX10 FPGA and want to measure the temperature via built-in temperature sensor. I have some LEDs on my PCB and I am controlling LEDs through PWM engine. I am measuring PCB...
10 years agoHi.
You may introduce signal called 'direction' for storage where temprature moves to. the you can create several conditions, for example cond1 := (direction = down) and (temp < 30) cond2 := (direction = up) and (temp > 35) then you can trigger events based upon conditions. Hopy you'll catch an idea.
