10 years ago[HPS] Peripherals Mux Table -> How to use?
Hi All, I need some clarification regarding the Peripherals Mux Table usage. How should I understand it? Is the First Column the Mux Output? Are the next columns the Mux Inputs? If so, let's ...
10 years agoDoes selection of the Set number (Set2,Set1,Set0) affect on the device pin where the mux output should be connected?
In the https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/dp/arria-v/5asxmb3.xls, there is a column H (tab EF31), which refers to the device pin. Why?
