10 years ago[HPS] Peripherals Mux Table -> How to use?
Hi All, I need some clarification regarding the Peripherals Mux Table usage. How should I understand it? Is the First Column the Mux Output? Are the next columns the Mux Inputs? If so, let's ...
10 years agothose with black border one is has been selected in the mux mode, you can scroll up alittle bit and there are some selection window to choose what muxing option that you need to utilize...the selection reflect the black border at the bottom.
