jwdonal
5 years ago"HPS Boot First" vs "FPGA Boot First" Mode (Stratix 10 SoC Dev Kit)
Hello all,
I've been reading up on boot modes for stratix 10 in the ug-s10-soc-boot.pdf (https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-s10-soc-boot.pdf) document. I...
EBERLAZARE_I_Intel
5 years agoHi,
I will try to answer both questions as much as possible,
Q1) Though which boot should be first, I do no think there should be file size different, as the settings may just be 1 line of string settings changes. I may need to reconfirm this. There seems to be an issue accessing the document that you pointed out.
Q2) I generate a S10 design file but never seen the file you mentioned, it may be your sof design file based on your Quartus project name. Can you recheck?
