14 years agoAltera finally fixed their /proc/bus/usb bug in Quartus 11, so now very little set-up is needed to use the JTAG. The only "special" requirement is that if you want to use it as non-root (which you probably do) then you have to create a file to tell Linux to grant access to all users. I use this:
$ cat /etc/udev/rules.d/51-usbblaster.rules
# Altera USB-Blaster rule to set mode to 666.
SUBSYSTEM=="usb", ENV{DEVTYPE}=="usb_device", SYSFS{idVendor}=="09fb", SYSFS{idProduct}=="6001", MODE="0666", NAME="bus/usb/$env{BUSNUM}/$env{DEVNUM}", RUN+="/bin/chmod 0666 %c" After you create that, run sudo udevadm control --reload-rules And then unplug the USB Blaster and plug it back in again. Note that for nios2-terminal to find the device you have to first launch Tools -> Programmer in Quartus and select the blaster device in Hardware Setup.
