14 years agoI was wondering if someone could provide me some guidance here? I cannot get the USB-Blaster working with Ubuntu 11.04 and Quartus 11. The error message that I get when I run "nios2-terminal" is
"There is no JTAG UARTS available which match the --device and --instance options you provided" The jtagconfig command shows 1) USB-Blaster [2-1] 081000DD I tried all possible methods available on this form. Currently I am using the approach that requires modification to rc.local. Any help would be appreciated. My windows setup works fine.
