15 years agoI installed the standalone programmer, and you are absolutely right, it's an x64 issue: unlike Quartus, the programmer does not come with 64-bit executables, and jtagd always runs the 32-bit version.
I've attached a 32-bit build of the library. If you run jtagd like you did before, you'll see a lot of LD_PRELOAD errors, which are harmless (they refer to native commands executed by the script), but jtagd itself should run normally.
