NTars
7 years agoHow we can run batch file after compilation any quartus project in quartus automatically?
I have one batch file that extract all the warnings lines from report file. After compilation process, we have all report files in our quartus directory. So, i want to run this batch file automatical...
- 6 years ago
Hi all,
I got one solution on this instead of using batch file.
I have designed one TCL script file which is executed after compilation has been done.
These are the steps to execute any TCL script file after Quartus compilation.
Steps :
- Add your .tcl file to your project directory which you want to execute.
- Add following command to .qsf file which can run tcl file after compilation process.
- set_global_assignment -name POST_FLOW_SCRIPT_FILE "quartus_sh:<tcl_file_name>.tcl"
3. Compile your project.
NTars
6 years agoNo. Still not getting any solution on this.
Do you have any solution?
Thanks in advance.
