11 years ago --- Quote Start --- You make another 'helper' IP core. Essentially create a Verilog of VHDL file like:
module pio_helper(
input pio1,
output piomerge
assign piomerge = pio1;
endmodule
Make a new component in Qsys using that module, and connect all your pio controllers to it. Then export the larger merged output from your Qsys system. --- Quote End --- Thank you again for your reply. I have a few questions: 1. when you said "make a new component", does it mean I have to make custom made component in Qsys where I need to assign the variables writeenable, chipselect etc?? 2. where do I get the pio controllers? 3. could you please provide me relevant resources to learn about this 'helper' IP core? I assume 'helper' IP core is not common name? where can I see examples of doing it in vhdl and Qsys? Thank you again for your kind replies.
