NuvKFC
Contributor
4 years agoHow to use wildcard to report all timing path in TimeQuest
Following picture shows the design.
Due to lacking of clock, the design use LCELL to generate a pulse to wake up system clock.
The design:
I use follow command to report the delay bet...
- 4 years ago
The report_path reports the longest delay paths and the corresponding delay value. That could be reason why only path from "Inp_dly1|dly1d|combout to "Inp_dly2|dly4d|data*" is reported.
Try to specify the start and end point if want to check the delay between the specific LCELL.
RichardT_altera
4 years agoYou can use the report_path command multiple time but you will need to use a different panel name else it will be overwritten.
NuvKFC
Contributor
4 years agoHi RichardTanSY_In
OK, I understand it. Thank you, RichardTanSY_In
