How to use wildcard to report all timing path in TimeQuest
- 4 years ago
The report_path reports the longest delay paths and the corresponding delay value. That could be reason why only path from "Inp_dly1|dly1d|combout to "Inp_dly2|dly4d|data*" is reported.
Try to specify the start and end point if want to check the delay between the specific LCELL.
- NuvKFC4 years ago
Contributor
Hi RichardTanSY_In
tel Oh, I get it. Thank you, RichardTanSY_In
tel, so much. Can I ask another question?
You said that "specify the start and end point if want to check the delay between the specific LCELL."
Could I use "report_path" command twice to report the delay into the same panel?
Ex.
(1)
report_path -from [ get_pins {top|IP_1|Inp_dly1|dly1d|combout}] -to [ get_pins {top|IP_1|Inp_dly1|dly2d|data*}]
-npaths 1000 -panel_name LCELLs_delay
(2)
report_path -from [ get_pins {top|IP_1|Inp_dly1|dly2d|combout}] -to [ get_pins {top|IP_1|Inp_dly1|dly3d|data*}]
There use "report_path" command twice.
Could the second "report_path" command report the delay that append into the same "LCELLs_delay" panel, but not overwrite?
Thank you very much.
