17 years ago --- Quote Start --- The SDC command for clock skew is
set_clock_uncertainty <your_uncertainty> <clock>
I might have the syntax wrong, but that's the name of the command. You can add this to the sdc file that timequest generates, then next time you open timequest and it reads the file it will load the setting. --- Quote End --- i will try it,thank a lot!
