gyuunyuu
Contributor
5 years agoHow to use the relative-vars option in the ip-make-ipx
The help message of ip-make-ipx says:
--relative-vars=<value>
Optional. Comma-separated list of shell variables, to which relative references are preferred
What is the purpose of this option a...
gyuunyuu
Contributor
5 years agoI created an environment variable and then put its name into the relative-vars. However, when the ipx file is generated, it does not contain the variable name as if it has been basically ignored. I do not understand why this is so.
RichardT_altera
5 years agoHmmm...not sure why it does not show up in the file. I have filed to the engineering team to check on this. While the engineering may takes some time to fix this, you may use the absolute path name in your .ipx file. It should work as usual.
Shyan Yew
