16 years agoHi Johannes,
I run some trials ( small project is attached). You should import all your partitions. After that you can specify in signaltap the nodes (choose post-fitting) you need. Only signaltap itself and the connection to the nodes will be new routed. You can find a good overview about the perservation level in the compilation report: Fitter -> Incremental Compilation Section -> Incremental Compilation Preservation Summary Kind regards GPK
