15 years agoall, right.
I have some questions for you. Q1. do you know custom IP? which means the IP-core which you make. Q2. can you access your SDRAM can you access your SDRAM some how? which means your system is connected to the SDRAM already. Q3. Do you know HDL? have you ever coded HDL and access to your hardware. OK, I wait your answer. and then I "may" teach you how SOPC builder works. unfortunately, I can not reply for 12 hours at least. see you.
