15 years agosince I don't have much time.
just quick reply. 1. what kinds of SOPC component do I use? you can make any type of IP-core, even CPU as well(it's not easy of course) Master / Slave / Stream sink / Stream source. 2. After using above SOPC builder component, do I have to use Eclipse Software for using SDRAM? or use verilog code to write/read SDRAM. no, your IP-core is able to access Memory Space directry like NiosII. also you can share memory between NiosII and your own HDL. 3. If I must use software for SDRAM data inout, I want to write some data to address of sdram, and read data from address of sdram using Nios II Eclipse (c or c++). you can write/read memory in C/C++.( convenient) you also can write / read memory via your own HDL.(fast) all right, I'm doing my job now. and I think this topic is going down and I can't find this again. you can e-mail to [email protected]. if i have time, I can teach you step by step.
