15 years agofirst of all.
why not using SOPC? the reason I guess is to access SDRAM via NiosII is too slow. you wanna access SDRAM as fast as it can. is that right? you can use SOPC builder and Avalon-MM "Master". you can use bast transfer via Avalon bus. this is easy way and safety way. otherwise, you need to write long long code in HDL. like this. ttp://cache.micron.com/protected/expiretime=1282712493;badurl=ahr0cdovl3d3dy5tawnyb24uy29tly80mdquahrtba==/fe03e95c6f6a764e10b3fbfff5a207f7/1/32/512mb_sdr.pdfreading and writing process is not difficult. but you need to write initial process and precharge process as well. I have done this before( for SDRAM / DDRSDRAM) it took months.( I was newbie too) now, I was studied I did not need to write this. SOPC is handy enough. if you still wanna try it, the hell is waiting for you. good luck.
