16 years agoAlthough dedicated to DDR2 memory, Altera AN408, that discusses in detail the properties of different SSTL termination schemes, is also interesting for DDR memory.
As a major difference, DDR doesn't provide parallel termination (ODT = on-chip dynamic termination) resistors. Thus according to SSTL class I scheme, parallel termination resistors are basically required for all address, control, dq and dqs lines. With short traces and at reduced clock speeds, an unterminated operation may be possible though. P.S.: Regarding the previous question of 50 ohm versus SSTL IO standard: DDR memory interface requires a voltage referenced standard. For this reason, only SSTL class x can be used. The calibration aspect (exactly meeting the nominal impedance) is only of minor relevance in my opinion.
