how to use design partition
for one big project, I want to use bottom-up flow with tcl mode is similar to xilinx OOC. the project has f top A, it instance B0, B1, B2,..B10 that has same entity B. after studying compile guideline, I want to execute the follow step:
step1: synthesis the module B and export an QDB by quartus_cdb cmd
step2: before synthesis top A, I need to designate instance name for B0, B1, ... B10 by the set_instance_name -name B.QDB -to x_B0 ?
If do, I think it is not frendly for implemening script automation!
You may refer to the Design Block Reuse Flows in Section 1.5 of the Quartus Prime Pro Edition User Guide:
https://docs.altera.com/r/docs/683247/25.1.1/quartus-prime-pro-edition-user-guide-block-based-design/answers-to-top-faqs
In this flow, you (as the Developer) compile the B project and export a partition snapshot as B.qdb. You then create a black‑box file for module B.
In the Consumer (top‑level) project A, the consumer adds the B black‑box file as a source in the project. After design elaboration, the consumer defines each instance of B as an independent design partition and assigns the exported B.qdb file to all B instances through the Design Partitions window.
Richard Tan
1 Reply
- RichardT_altera
Richard Tan
