how to use decode_address_map tcl command
We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
KhaiY
Hi KhaiY,
Thx for your reply, I was not able to respond.
I still struggle to use this example.
set address_map_xml [get_parameter_value my_map_param]
set address_map_dec [decode_address_map $address_map_xml]
foreach i $address_map_dec {
array set info $i
send_message info "Connected to slave $info(name)"
What is used for the my_map_param value?
My custom avalon_master module is called "dummy"and gets the name dummy_0 once instantiated in qsys.
I added this piece of example code to the elaboration process of the dummy module, dummy_hw.tcl.
This results in an error.
Error: invalid command name "decode_address_map"
I tried to add the code to the instance parameter tab of the design, this also results in the same error error.
any ideas? A small design where this is used would be helpfull.
Willem
