14 years agoHow to use Avalon-MM Master BFM?
Hello, all. I want to use Avalon Verification IP Suite to check a Qsys custom componet, which have an Avalon salve interface and a Avalon conduit interface connecting a LSI. I wrote this p...
13 years agoI've very little experience with Verilog/SystemVerilog, so cannot provide much help in this area.
What happens if you write this as two separate tasks, i.e., task master1_set_and_push_command and task master2_set_and_push_command? This would result in the two BFMs being accessed from different tasks ... it would also result in unique objects/variables being passed to the BFMs, rather than common variables as you are using now ... though push_command() should copy everything allowing you to reuse those same variables in a subsequent call. Cheers, Dave
