10 years agoHow to use a module or interface instance in an interface?
Hello,every one! I have some problem in using interface of SystemVerilog: I have a predefined module and interface, and I want to use them in another interface. The example code of module in int...
10 years agoaltera will only support the majority of use cases - extreme and corner use cases wont be covered unless there is a good market justification (ie. without it you'll buy a few $mil of Xilinx instead of Altera).
While an interface within an interface is legal SV, I cant really see it being of any use that would make anything easier. If you really want it supported - raise a mysupport request with Altera (Altera dont really monitor these forums). They will give you a much better explanation as to why it's illegal.
