10 years agoHow to use a module or interface instance in an interface?
Hello,every one! I have some problem in using interface of SystemVerilog: I have a predefined module and interface, and I want to use them in another interface. The example code of module in int...
10 years agoRemember that Quartus only allows a specific subset of the language, as it must map to a real design.
Interfaces are usually self contained from a real point of view, and should not contain another interface. SV is a very broad language that mostly covers verification. Quartus only supports the following: http://quartushelp.altera.com/14.1/mergedprojects/hdl/vlog/vlog_list_sys_vlog.htm
