10 years agoHow to use a module or interface instance in an interface?
Hello,every one! I have some problem in using interface of SystemVerilog: I have a predefined module and interface, and I want to use them in another interface. The example code of module in int...
10 years agoYou dont need to use interfaces at all. Modules contain other modules or interfaces. Interfaces just define a behaviour of a bus, and in real designs you dont need to use them at all.
If you have a behaviour that needs to go into an FPGA, use modules. And instantiate modules inside modules.Interfaces just complicate things.
