DTruj3
7 years agoHow to update the top level design file in pin planner?
I am trying to update the top level design file after I change pin assignments in pin planner. Only options I can find is to create a new top level design file, but I don't want to do that.
KhaiChein_Y_Intel
7 years agoHi,
If you make any changes in the Pin Planner, the design will be updated with the new assignment after the compilation.
DTruj3
7 years agoYY
Thanks for responding!!!
I changed node locations in Pin Planner and when I recompiled I got the error "Error (171173): Node led[1] from partition Top cannot preserve previous placement at PIN A23 and honor the location assignment to PIN AK29" The only way I found that could clear the error was by removing the assignments.
However, now I can't replicate the error. When I change pin assignments and recompile I have no issues.
