13 years ago --- Quote Start --- You can use the LCELL primitive, these won't be removed by optimization. Note that the control you have over those delays is poor. It's subject to placement, process, voltage and temperature variations. Depending on what you need, using the programmable delays on the output elements might work better. Also, do you really need those delays? --- Quote End --- I found this whilst googling but isn't the LCELL primitive turned off by default now? Or that is what it appeared to be when i found the option in the software.
