How to tell the compiler that store operations are not dependent?
Hi HRZ,
Yes, that makes sense. The current design is just testing version. In the main design I will vectorize the output data to make efficient use of memory bandwidth.
I am also having some issues where this design works in the emulation mode (with strict channel depths) but on the FPGA it is giving wrong results. I am facing similar issues for another benchmark as well. I am using aoc 17.1 on Virtual Lab (VLAB) from Intel. Have you ever faced this issue? Here is the code: https://drive.google.com/file/d/1QcMYwOPU9onk4CiZx6YFD1pEYjXOSsbY/view?usp=sharing Can you see if there is any obvious bug?
Here are the commands that you can run. (You might need to modify the Makefile according to your aoc setup):
% make compile-emulation
% make compile-host
% make run-emulation
This will pass and give correct results.
FPGA flow:
% make compile-device
% make compile-host
% make run
runs it on FPGA but the results are all 0s
Nitish
