12 years agothere are some multi-PHY TT designs here:
http://www.alterawiki.com/wiki/transceiver_toolkit the conduits are actually connected internally, i didn't think you could do that at any rate, after opening the multi-PHY design it sounds like you may have the reconfig block setup incorrectly if you are "splitting" the conduits into multiple buses. you should have two separate conduits (two tx/rx pairs), one for the PCIe and one for the "transceivers" (assuming they are all part of one PHY). no manual splitting of the reconfig bus should be necessary
