sqd0524
6 years agoHow to speed up simulation in Modelsim SE 10.4
I use Modelsim SE 10.4 to simulate LDPC IP core generated by Quartus, but it runs too slowly. It uses 1 second to simulate 4 clock periods. How can I speed up the simulation?
Sanket_Doshi
6 years agoDepending on your install, your simulator resolution may be picosecond by default. Check your
modelsim.ini and look for the Resolution variable under the [vsim] header.
Alternatively, you can force the resolution on the command line. You are very close to your example. The syntax is
vsim -t ns for nanosecond resolution.sqd0524
6 years agoHi Sanket_Doshi:
The Resolution variable under the [vsim] header in my modelsim.ini had already been setted as nanosecond. But my simulation on LDPC IP core runs very slowly. I want to know how to speed up the simulation. The modelsim's verison is ModelSim SE-64 10.4.
Thank you!
