Altera_ForumHonored Contributor13 years agoHow to specify timing constraints between 2 memory ports I have a design with 2 memory read ports (M1 and M2) connected as follows M1 ---> combinational-gates----> M2 i.e. M1's data out feeds the address of M2. M1 and M2 are clocked by the ...Show More
Altera_ForumHonored Contributor13 years agorbugalho, rysc: makes a lot of sense! I will try this and update.
Recent DiscussionsInterfacing Avalon Streaming FIFO IP with GTS Ethernet Hard IPInvalid license key (inconsistent authentication code)Regarding the issue of UFM not startingram retimingReset Release IP for Agilex needs Stratix 10 device files installed!
