13 years agoThe "more correct" way would be to put generated clock assignments(where the -source is whatever drives the counter's clock) on the counter bit that creates the clock. That way skew will be accounted for back to the clock source.
If you make the exclusive/unrelated, there is no way to re-relate them, as false paths, clock groups always have priority.
