JLoh3
7 years agoHow to solve error: Out of memory in module quartus_map.exe?
I am using Cyclone V DE1-SOC board and I am running my design in Quartus Prime Lite 18.1. The processor that I am using is Intel Xeon [email protected] and it has 128GB RAM. It seems a bit unreasonable...
CalvinJoaz_P_Intel
Contributor
7 years agoHi JLoh3,
You getting this error message is because the available memory is insufficient to continue running or to perform the specified operation. Try compiling again by closing other background task to make enough memory to run Quartus Prime.
Refer link below for more infomation.
Refer previous thread with similar issue.
Thank you.
- JLoh37 years ago
Hi, I am aware of the previous post, however I think it is quite not reasonable to use up to 162GB memory while Cyclone V device itself actually only requires 6-8GB RAM.
