15 years ago
How to simulate TDF with ModelSim Altera ?
I'm trying to use ModelSim-Altera to simulate a design that contains TDF design files.
I have no problem simulating Verilog files with the ModelSim SW directly (not passing through QuartusII). using a behavioral test bench.
However, when TDF files are introduced, obviously ModelSim can't compile them.
so trying to compile my files in quartusII, but since the TB is not synthesizable, I get an error that the file contains no logic !
so, the question is:
How do I simulate in modelsim a behavioral testbench that contains a design with AHDL files ???
1 Reply
    ok. found the problem
    I used "Compile and Synthesize" in QuartusII, instead of "Compile and Elaborate"
    now things are working :)
