How to simulate FFT IP Core in Modelsim.
- We have to use modelsim with respect to the Quartus version used to generate the fft design. please check the image attached and link. https://www.intel.com/content/www/us/en/programmable/downloads/download-center.html
- Are you using Quartus 16.1 and Modelsim SE 10.5b? it should work fine.
I have used Quartus 17.1 STD and Modelsim 10.5b under windows 10 environment. i was able to compile without any error.
Attached the transcript .
Anand
- ONors7 years ago
I was using this version of Quartus. Quartus Prime Design Software Version 16.1.1 Build 200 11/30/2016 SJ Standard Edition.
I think the version of Modelsim is also from the 16.1*-version, but since Moelsim uses different version numbers than Quartus it is a bit difficult to tell.
vsim -version
Model Technology ModelSim ALTERA STARTER EDITION vsim 10.5b Simulator 2016.10 Oct 5 2016
I went to the download page you linked to and saw a update to Quartus. So I updated to Quartus Prime Design Software Version 16.1.2 Build 203 01/18/2017 SJ Standard Edition.
I also uninstalled Modelsim and installed ModelSimSetup-16.1.0.196 from the same download page.
vsim -version
Are these versions compatible?
With the new versions and after regenerating the IP I still have the same error when compiling it in Modelsim.
- AnandRaj_S_Intel7 years ago
Yes, Tool versions are compatible.
Can you please delete the db , incremental_db and libraries folders regenerate the qsys design and check.
If possible please attache Modelsim transcript.
Anand
+ attached project file
Please try to simulate the file.
