13 years agoHow to simulate an inertial delay in ModelSim?
I am attempting to simulate an inertial delay in ModelSim. The code compiles in Quartus II; however, the delays in my code are not showing up in the simlation. I assume it is a configuration issue, b...
9 years agoHi everybody, I am trying to simulate delay introduced by LCELLs chains with timing simulation in ModelSim.
I reduced the block to a DFF with output fed back to CLRN through a chain of LCELL. I output .vo file from QII, setting the Ignore LCELL buffers OFF. I include maxii library in the ModelSim project. Would you please have a quick look at the attached project? It might be I am missing something very basic and I do not see it :( Thanks!
