Got a favourite language? In VHDL you could do something like: b <= b(2 downto 0) & '0'; assuming b is defined as a four bit std_logic_vector. Mark. - Altera_Forum
you could do that, but it wont work without registers. Its called a shift register for a reason...
--- Quote Start --- you could do that, but it wont work without registers. Its called a shift register for a reason... --- Quote End --- Well, yeah, the behaviour of that line of code is entirely dependent on what's around it. On it's own it doesn't hold a value or anything. The OP's question was a little vague... Mark. - Altera_Forum
Thank you for answer!!!
