8 years agohow to share DSP correctly ?
16bit or 8bit multiply should only use 0.5 DSP. I have try to implement two char type MAC, and the result will be store into int type. The DSP usage should be 64x16/2=1024/2=512 and in repo...
8 years agoI have remove printf, and result is the same.
I am talking about https://wicil.ece.wisc.edu/wp-content/uploads/2017/02/jzhang_fpga17_cnn.pdf the author use SDK 16.0.211, so I think maybe it work well with SDK 16.0.211. if the report.html can show two 16-bit x 16-bit multiplications per DSP, it shouldn't require complex bit masking. However, my BSP only support quartus 17.0, so I can't try 16.0.211. by the way, the author says they limit the maximum fan-out to 100 to increase frequency, and they got a very high fmax of 385 MHz, do you know how they achieve that? I always get Fmax 200 ~ 300 MHz, I also try use "aoc -c" first, and use quartus to set fan-out, but still have l
