12 years agoHow to setup the Quartus 13,1 in Ubuntu 12.4.1?
I am new about the Quartus in Linux (also new in Linux). I just install Quartus 13.1 in my Ubuntu. Then I can only start Quartus in the folder I installed. How should I do setup that I can start Quar...
10 years agoUbuntu isn't a supported OS for Quartus. I've had good luck with Centos as it is close enough to red hat to have the right system libraries. There have been several threads on what is needed to install Quartus in Ubuntu Linux. You basically need to add some libraries that Quartus needs but don't come with Ubuntu. You should be able to find several threads on this in the forum.
