12 years agoHow to setup the Quartus 13,1 in Ubuntu 12.4.1?
I am new about the Quartus in Linux (also new in Linux). I just install Quartus 13.1 in my Ubuntu. Then I can only start Quartus in the folder I installed. How should I do setup that I can start Quar...
12 years ago --- Quote Start --- I'm not quite sure I understand your question. If you set the QUARTUS_64BIT environment variable as shown above Quartus will start in 64-bit mode. You don't have to check it. If you don't want to run the 64-bit version of Quartus simply don't set it. --- Quote End --- Hi petter, Sorry that I didn't clarify my question clearly. So as you mentioned QUARTUS_64BIT is an environment variable. But after I installed Quartus, how can I know I should set this environment variable "QUARTUS_64BIT" to configure the Quartus working in 64 bit mode? What document did you check? I think it should be some documents from Altera. Hope I clarify my question clearly this time. Thanks.
